Sub calibration - sine or warble tones ?
Discussion in 'Archived Threads 2001-2004' started by Steve McWilliams, Aug 3, 2001.
  1. Steve McWilliams
    Jul 6, 1999
    15
    I just got the Stryke Basszone CD the other day, but I'm not sure whether I should use the warble or the sine wave tones to chart out my frequency response. Does it matter ?
  2. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    The warble tones are good for checking the crossover frequency between mains and sub to ensure seamless SPL levels at the crossover frequency.
    The sine wave tones will show your room's actual sonic environment with the frequency peaks and nulls created by the reinforcement of room reflections (for the bass region typically
  3. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,241
    20
    1,610
    Right, if you're trying to chart the response as it will typically be effected by the room interactions...use the sines.
    and as noted, DON'T run them loudly. Since it's just a simple response chart you're after...use a low 75-80dB level.
    TV
  4. Steve McWilliams
    Jul 6, 1999
    15
    Thanks, guys. I was doing it at 75-80db SPL already, because that's the level I watch movies at. Now I don't have to waste time charting both types of waves.
