Sub building materials
Discussion in 'Home Theater Projects' started by Dean-P, Sep 2, 2003.
  1. Dean-P
    Dean-P Stunt Coordinator
    May 18, 2003
    134
    I was assuming that mdf was the only product really to be used until I read the tempest "Adire" building sheets and it stated "building materials are void free plywood (such as marine ply, apple ply, or baltic birch)and MDF".
    Does this mean I can use veneered plywood such as oak, regular birch with a plywood core?[​IMG]
  2. Bob Kavanaugh
    Bob Kavanaugh Second Unit
    Jan 17, 2003
    282
    Yes, many people choose to use MDF because it is heavier ( ~80lbs a sheet), cheaper (less than half the cost of veneered plywood), and can accept a variety of finishes. Some even feel it has "special dampening qualities".
    Knock yourself out, but I have to ask, what are your plans?
  3. AllanRW
    AllanRW Second Unit
    Nov 30, 2001
    342
    Talk to Dan at Adire .
    He is liking Plywood much better over MDF.
    Go veneered Plywood 3/4" and you will be fine.
    Al
  4. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    I recently build an audio rack and pi speakers out of Baltic Bitch and loved the way they came out. it can take a really nice finish and you don't have to worry about veneer and such.
  5. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    MDF tends to "dampen" higher frequencies. That's why it's best for full-range speakers. At sub frequencies, it doesn't do any better than plywood. Note that we're talking solid core plywood, like Baltic Birch or Appleply. Regular plywood has several internal voids. A benefit to using the solid core plywood is that you'll actually be able to lift your sub.
  6. Dean-P
    May 18, 2003
    134
    Thanks for the replies; I'm going to use 3/4" mdf covered in 1/8" oak ply...trying to match my Athena Audition series. I'll try to post pics when I'm done.
    BTW Bob K I'm building a 85l Shiva sealed unit.
  7. Jonny K
    Jonny K Second Unit
    Dec 18, 2002
    375
    Hmmmm...sounds heavy. (literally).
    My Tempest uses the Adire Alignment and it's made mostly from MDF (with some plywood for the inner supports). The thing is so heavy that I can't safely carry it on my own (or risk hurting my back trying).
    Jonny K. [​IMG]
  8. David Giesbrecht
    David Giesbrecht Second Unit
    May 28, 2001
    306
  9. Allen Ross
    Sep 30, 2002
    819
    casters thats all i have to say, with the hardware out of my tempest i could move it, barley, even up stairs [​IMG] its around 100-110 lbs w/o driver and amp so 150-175 all together. But now she is mobile with 2/5" casters from HD she rolls with the flow and when locked down she doesn't budge and inch
  10. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    Edit: Never mind. Inappropriate out-of-context quote from Allen Ross' post.
  11. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
  12. Jake K
    Jake K Stunt Coordinator
    May 22, 2003
    132
    About how much do the different types of plywood cost compared to MDF?
  13. Jonny K
    Jonny K Second Unit
    Dec 18, 2002
    375
    Plywood is more expensive, but much lighter. I just can't give you any exact prices.
    Jonny K.
  14. Dean-P
    May 18, 2003
    134
    I called today for the 3/4" mdf, it runs about $22/sheet and the 1/8" oak plywood costs $30/sheet. I'll be able to cover my sub and my A/V-3s and still have leftovers.[​IMG]
    3/4" oak plywood(regular core)costs about $55...
    (all prices are in canadian $)
  15. Bob Kavanaugh
    Jan 17, 2003
    282
    Here in GA , 4x8 3/4 MDF runs ~$18 and oak or birch 3/4 ply is ~$40 a sheet.
    I keep meaning to call the lumber yard(s) to get prices, to compare them to Lowes / Home Depot
  16. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
