Sub and Amp
Discussion in 'Home Theater Projects' started by Peter Moss, Oct 26, 2003.
  1. Peter Moss
    Peter Moss Auditioning
    Oct 25, 2003
    3
    I own a Samson S700 (350w X 2). I recently inherited a SonoSub that uses a 12in Single Voice Coil Sub Speaker Driver rated at 4ohm. I would like to bridge my amp to provide 700W to the sub since the driver is rated at 1000+. Only problem is, the amp manual states that, once briged, the Amp need to be connected to an 8ohm speaker. Since mine is SVC and only 4ohm, what do I use to turn my 4ohm into an 8ohm. I know I can use resisters but what will that do to my power and frequency response. Any suggestions so I can use the full 700W?
  2. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    The only way to do it is with another 4 ohm subwoofer. I tried bridging my Samson S1000 for little bit powering a 4 ohm sub...let's just say it didn't like it.
