Sub Amp
Discussion in 'Archived Threads 2001-2004' started by Meaux, Dec 20, 2001.
  1. Meaux
    Meaux Stunt Coordinator
    May 27, 2001
    168
    I have a Adcom 555, 200wpc or 600 bridged. I'm going to use 2 8ohm subs. Should I just go w/ a 2ch. setup, or bridge the amp? Then the 2 8ohm subs wired in paralell would put a 4ohm load on the amp, series it would be 16ohm. Which way would you guys go?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,100
    33
    Katy, TX
    Wayne
    Meaux,
    It would be best to just go two-channel. The Adcom is not designed for 4-omh loads bridged, and 16 ohms would suck the power down to 300 watts, or 150 per speaker.
    Happy Holidays,
    Wayne A. Pflughaupt
