Sub advice...One or Two?
Discussion in 'Archived Threads 2001-2004' started by Phil Mays, Aug 11, 2002.
  1. Phil Mays
    Phil Mays Second Unit
    May 20, 2002
    361
    Currently I have a Klipsch KSW-15 Sub. It has done well with little complaint from me with the exception that it tends to be a little "boomy" with music.
    What is better:
    1. two smaller subs
    2. two larger subs
    3. one better quality sub
    4. DIY sub (I'm fairly good with wood,etc)
    5. Other that I have not thought of.
    Thanks for your advise!
    Phil
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    If you are good with wood and would enjoy the project, 4 hands down.
    What type of budget are you working with?
  3. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    I'd have to say #4 also. As I've said before, pick a price point (any price point). A DIY sub at a given price point should almost always bury a commercially available sub or speaker at that same price point. There are 1 or 2 exceptions, but only at the really low end of the spectrum, AFAIK.
    Brian
  4. Phil Mays
    May 20, 2002
    361
    Thanks, I will journey on over to the DIY area and read the posts.
  5. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I would opt for a kilelr DIY sub. Choose a driver that has a heavy duty magnet and good peak to peak excursion, design a nice ported tube or box with sufficient volume and porting and away you go.
