Jacob C
- Mar 19, 2005
Hi everyone, this is my first post. Im not looking to go all out here right now but I really need a nice stereo pair for music. I am looking for a full range speaker that can eventually make up the fronts on a 5.1 system. I heard some polk towers (dont remember the model #) but they seemed to be lacking, though it could have been the setup at Circuit City. I also ran across Axiom's site and the M60ti sounds like they are what I am looking for. I have not purchased an amp/receiver yet so I'm not limited there. The room these will be in is rather small but I do plan on moving into a bigger place at some point so I want to have something that is able to fill a bigger room. They will be used 95% for musics initialy but I need them to perform well for movies as I dont want to buy another pair when I build my home theater. I listen to a wide variety of music from jazz to rock to classical to electronic so I need somethig with solid but defined bass as well is a well articulated midrange. While will primarily be used for entertainment I will also be using them to trasncribe music and mastering soundtracks on some small independent movies. This demeands the speakers have a flat response (i.e. minimal coloration) to preserve a good balance on the movie track when played on other speakers. (i.e. if my speakers are weak on bass I may overcompensate and raise the bass level too much) That said, I am looking for a good soundstage as well. I like speakers with crisp airy highs but I am willing to go with a with a 'warmer' sound if that is my best option in this price range. I know this is a tough order for less than $1000 but thats all I can possibly get together at this point. Please let me know if I have overlooked anything I should consider in a speaker. This is my first time buying a decent set of speakers. Other than that my best set are my polk db 6x9s in my car. Many thanks to those who take the time to respond.
