Stupid weather-stripping question
Discussion in 'Archived Threads 2001-2004' started by Ronnie Ferrell, Nov 8, 2002.
  1. Ronnie Ferrell
    Ronnie Ferrell Second Unit
    Jul 16, 2002
    355
    This is probably a stupid question and it probably does not make a difference. But I was wondering what size weather-stripping most of you use for sealing up your subs. Also do you put it on the back side of the driver basket, or do you put it on the front of the enclosure?
    Thanks!
    Ronnie
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,737
    474
    9,110
    I put it on the enclosure (in case you need to return the driver, I doubt if the manufacturer would like the gunky stuff on the driver rim). If you recess the driver, you can put the weather stripping inside the recess perimeter.
    Most people will suggest closed cell foam weather stripping. I've gotten by with open cell foam (highly compressible) weather stripping for some of my projects.
  3. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    I put it on the driver basket. There shouldn't be any problem getting the gunk off the driver with a little Goo Gone or something like that. Peanut butter works well in a pinch! [​IMG]
  4. Ronnie Ferrell
    Jul 16, 2002
    355
    Do you apply it, be it to the basket or the enclosure so that some of the tape laps over the cut-out lip and actually tucks into the cut-out or is it attached only to the outer flat surface of the enclosure or basket?
    (yes, before you ask, I always make mountains out of mole hills... [​IMG])
    rf
  5. Brian Bunge
    Sep 11, 2000
    3,716
    Ronnie,
    I just apply it to the flat part of the flange.
  6. Patrick Sun
    Jun 30, 1999
    38,737
    474
    9,110
  7. Ronnie Ferrell
    Jul 16, 2002
    355
    Thanks for the info! After more reading, I really want to try the 1/4" rope caulk. But I am afraid I could not get my driver back out after installing it since I flush mounted it. I guess I could pull the plate amp and then reach into the cabinet and push the driver out. Would this be possible, or does the rope caulk REALLY hold?
    Ronnie
  8. Patrick Sun
    Jun 30, 1999
    38,737
    474
    9,110
    You might need to use a flat head screwdriver to pry the driver out/off.
  9. Ronnie Ferrell
    Jul 16, 2002
    355
    Yeah that is why I am worried about using the rope caulk. The driver is flush mounted with a 3/4" deep rebate and there is no way to pry under the driver. I could only put pressure on the driver from pushing from within the enclosure by reaching through the amp cut-out.
    I will stick with weather stripping!
    rf
  10. Brian Bunge
    Sep 11, 2000
    3,716
    When I built my dual SV12 subs I flush mounted the drivers and used the small pieces of foam that were made to fit on the back of the driver frame. I can't get the drivers out now. I actually took out all 8 screws and cranked up some bass heavy music and the driver just pounded away! Of course, I painted the cabinets but I let them dry for several weeks before installing the drivers. And since there are no amps to remove from the cabinets there's no way to get to the back of the drivers to push them out. I may eventually get some angled needle nose pliers and see if I can pull it loose from the mounting holes.
