Stupid Question: Please Help
Discussion in 'Archived Threads 2001-2004' started by carlos f, Mar 20, 2002.
  1. carlos f
    carlos f Extra
    Mar 8, 2002
    19
    I have a Sony ES30 Receiver and I lost the manual. I need to change some speaker settings and a few other things but I can't do it on the receiver or remote, so I'm assuming I have to do it from the OnScreen Display Menu.
    My stupid question is how do i connect the receiver to my TV in order to access this menu.
    I tried a few different things but nothing works.
    Please Help!!!
    BTW: I have a Mits ws55857
  2. Adam Krogul
    Adam Krogul Stunt Coordinator
    Feb 25, 2002
    66
    i thought you were able to go into the menu on the lcd panel of the reciever? i could be wrong. but if you want the osd (on screen display) you would hook up a composite cable to the monitor out of your reciever and connect it to video 1 in on your tv.
    l8rz
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    You will also need to switch to the input that you hooked the vid connection to, and switch to amplifier controls on the remote. There may also be a setting for OSD on or off, which my receiver has, so one does not accidentally change settings while in the AMP mode on the remote.
