Stupid Question About Double-Sided Discs
Discussion in 'Archived Threads 2001-2004' started by Andrew_Sch, Aug 15, 2002.
  1. Andrew_Sch
    Andrew_Sch Cinematographer
    Dec 30, 2001
    2,153
    Okay, here's my stupid question: On a double-sided disc, does a side actually contain the information that corresponds to its label, or are they labeled opposite just to make it easier, so you can stick it face up. For instance, does the side of a disc labeled widescreen actually contain the widescreen transfer, or is that really on the side that is labeled pan and scam?
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    The label side up, the data side down. Just like a CD- if it say METALLICA, it's the other side that actually contains the audio data.
    So, on a "Widescreen" inner label- the data layer containing the widescreen version is on the other side.
    -V
  3. Andrew_Sch
    Dec 30, 2001
    2,153
    OK, thanks for clearing that up. Any admins, feel free to kill this thread now.
  4. Yee-Ming
    Yee-Ming Producer
    Apr 4, 2002
    4,375
    16
    610
    "on a little street in Singapore"
    Yee Ming Lim
    just to add, though, that sometimes they make a mistake, e.g. my copy of Das Boot, which is a flipper, side A label is also side A data, which is wrong. I think I've seen reviews which noted that WS and pan-and-scam sides were sometimes mis-labelled as well.
  5. TheoGB
    TheoGB Screenwriter
    Jun 18, 2001
    1,744
    This confused me when I got my first 'two-sider' - T2: UE.
    I assumed it was labelled like an LP and so stuck in side B when I expected Side A. It took me quite a while of hunting through the menu system for the movie before I worked out what I'd done!! [​IMG] :b
  6. Bernhard
    Bernhard Stunt Coordinator
    Mar 10, 1999
    192
    Just one more comment to add: There no such thing as stupid questions.. there are just stupid answers. [​IMG]
  7. HenrikTull
    HenrikTull Second Unit
    Jun 6, 2000
    469
  8. Chris M
    Chris M Second Unit
    Apr 15, 2000
    487
    Actually, I had a problem with Revenge of the Nerds double feature, I wanted to watch I so put that label side down and ended up watching about 30 mins of II before I figured out that this wasn't right [​IMG]
    Confusing. heh
    Chris.
  9. jacob w k
    jacob w k Stunt Coordinator
    Jun 17, 2002
    172
    I got annoyed by the two disk set of From Dusk to Dawn with the movie being on disc 2 and the documentary on disc 1. Took me a few minutes to figure out where the movie was.
