Stupid Question about Cable
Discussion in 'Accessories, Cables, and Remotes' started by Brian-H, May 7, 2005.
  1. Brian-H
    Brian-H Auditioning
    Mar 8, 2005
    2
    Seeing as AES/EBU which is normally 110ohm also exists in a 75ohm format, is it acceptable to go the other way and use a 110ohm cable for an S/PDIF coax signal?
    Also, anyone know if canare or mogami makes a 75ohm coax cable for digital audio as opposed to video?
    Forgive my ignorance.
    Thx.
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    if it's 75ohm it'll do fine, regardless of whether it carries a "video" label. 75ohm is 75ohm, can be used for either application just fine.
