Stupid Folder Question..
Discussion in 'Archived Threads 2001-2004' started by DeathStar1, Feb 8, 2003.
  1. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    How can one lock a folder so it can never be deleted, at least accidentally, in Windows XP? Sometimes I get to hasty in DVD Authoring, and select the wrong files to delete, causing other DVD Folders to go the wayside....
    It'll save me a few hours work to make the folders undeletable [​IMG].
  2. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
    Not stupid at all...it's a good question. Anyone know?
  3. John Watson
    John Watson Screenwriter
    Jul 14, 2002
    1,937
    And can we passpord a folder, instead of every stupid little document in it?
    [​IMG]
  4. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    The only thing I can think of is setting the individual files to be read only. The command is attrib
    To make a file read only enter (from a DOS window):
    attrib filename.ext +r
    To make a file read/write again:
    attrib filename.ext -r
  5. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    The read-only prompt doesn't seem to work very well.
    Safest way would be to create the files and folders in whole logged on as a different user, with the permissions set to Read-Only for the the user you use to work on then.
  6. Tony-B
    Tony-B Producer
    Jun 30, 2002
    3,768
    You can right click the folder, go to properities, and choose read-only.
