1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
stuffing a JBL PB10
Discussion in 'Archived Threads 2001-2004' started by Matt Weyen, Mar 16, 2002.
  1. Matt Weyen
    Matt Weyen Stunt Coordinator
    Mar 5, 2002
    51
    Ihave a JBL PB10 and it isn't stuffed at all. Should I glue stuffing to the outer walls (inside the sub obviously) to improve the sound or leave it as is?
    thanx-
    MW
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    It helps in many cases. You WILL void the warranty, if you have one.
    Try it without the glue first. Look for pillow stuffing, and pack it loosely, but enough to make it about 60% full.
    Listen to see if it gets smoother, deeper.
    Good Luck!
