Brandon B
- Mar 23, 2001
Building a dual HE15 sub with 6 of the 15" PR's from Stryke, and as this effort is going veeeery sloooowly (no time for fine woodworking between job and kid), I put together a dirty but solid cube per the original single HE15 with 3 PR's design. I lined it with polyfill, but did not stuff it.
A few minutes into running the thing, one of the PR's started chattering. Inspection revealed that the surround on the PR had come unglued from about 45 degrees of the textured face of the PR. It peeled away pretty cleanly, meaninng the glue had failed without ripping the surround or the face of the disk.
First time any of these components have been used. I was running it at fairly modest levels (for this sub), and it happened almost immediately.
So my question. Was this just a bad glue job on the PR? I ask as it was the one opposite the driver, which means it gets the full brunt of the backwave. If this happened because I did not stuff the box, I don't want to put one of my other 3 PR's in there and do the same to it if it was my error. If not, I would like to "test" the other 3 so I can get them repaired all at once if there are similar problems. (and have a working sub until I finish the other enclosure.)
Thankns.
BB
Thankns.
BB
