Evan S
- Nov 21, 2001
OK, in the search to make the move to 7.1 I can take either of two routes and I was hoping for feedback from the board.
I have an Anthem MCA-5 5 channel power amp and an AVM-20 processor. To go to 7.1, I would have to get another 2 channel amp and a set of Studio 20's for rear surrounds (Currently have Studio 40's for fronts, CC in the center and Studio 20's as rears). I could do this by either buying a cheap two channel amp to power the surrounds or buy a great used two channel amp to power my mains and run the surrounds off the MCA-5.
Or, I could get a pair of Active 40's for the front. I know they have been discontinued, but have seen them for $2K used. I figure by going this way I can get slightly better two channel performance (for I have heard the Active 40's are AWESOME) and not have to worry about finding rack room for another amp.
Which way do you suggest? Any Active lovers out there? Seems like I could get a great used Classe amp for around $1K and a set of Studio's for less than the Actives alone but some people swear by the Actives.
Thanks for the input.
