Stryker test disc? Autosounds not delivering.
Discussion in 'Archived Threads 2001-2004' started by Larry Rasmussen, Dec 19, 2001.
  1. Larry Rasmussen
    Dec 6, 2001
    28
    Waiting for my SVS 16PC46, been using very dated Stereophile test disc for set up on other subs but wanted to upgrade. Ordered Autosound test disc on line Nov 30 with email response and order #sent back immediately. No disc, no charge to credit card, no response to email inquiry about the order sent 3 days ago. Thought I'd look at the Stryker disc that I see mentioned. Could anyone discuss some of the differences between the two and post a link to site to purchase? Thanks in advance.
  2. Dzung Pham
    Dzung Pham Second Unit
    Mar 10, 2001
    271
    The track list for the Stryke Bass Zone Test Disc is here.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    You might want to give them a call.
    I have both, and both are useful.
    The Autosounds disc gives you 10 to 98 Hz, in 1 Hz increments.
    The Stryke disc give you the full spectrum 20 Hz to 20 kHz, but only in 1/6 octaves up to 160 Hz, and then 1/3 octaves the rest of the way.
    Personally, I use the Autosounds disc as my main disc, and then the Stryke disc as a "check" for frequencies above 98 Hz.
  4. TerryC
    TerryC Stunt Coordinator
    Oct 19, 1999
    218
