Has Anybody heard the Stryke, how does it sound? Im planning on buying one of these, but if i go with the stryke i can save $50! Is the titanic worth the extra money?
I am running a SAE1204 with 2 PR's in a 80l box, tuned to 21hz. I think it sounds very good. This driver is basically very close to the 12" Dayton DVC that is so popular, quite similar to a Shiva.
As far as saving $50, what are your goals for the sub, what alignment are you planning on building? It all depends on what you are after. If I was looking at the Titanic, I think I would buy the Stryke AV12 instead- that's the driver I would be looking at. . .
