Jack Gilvey
- Mar 13, 1999
I just multiplied 804 cm^2 Sd by 2.6cm Xmax. That gave me 2090 cm^3, or 2.1 liters one-way. Is that the way to do it?
Bob,
I'm starting to believe the line just below your name.
Hehe, yeah, I fully admit it! The last thing I need is another subwoofer, but I just like playing with these things so much I couldn't resist the temptation.
Besides, I have some really needy friends
I know what you mean, I have more projects on the burner than I can hope to complete.
I am also working with Thilo right now on a few variations of the HE15. One will be using a copper faraday, similar to the Lambda drivers to further lower distortion, and lower the inductance. The other variation will be going with a longer VC and slightly shorter gap plate of 1" thickness instead of 1.4" thickness. This will give 25.4mm overhang and should dumax at right around 29mm. Most likely i will go with this longer VC AND the copper sleeve.
Great, more drivers I'll want. It appears that we're in the midst of some sort of "arms race" in regards to sub drivers, all kinds of great stuff hitting the market.
Is materials technology driving this, or other advancements?
Yeah, like Thomas says, the Tempest's lower Fs will allow it to play lower in the right enclosure.Looking at it quickly in Unibox, if you just put a 1503 in your box of fixed Vb,they look pretty close.
The Tempest seems to have a bit more output/sensitivity in the upper bass, the 1503 shows a little
more deep bass around tuning (its lower Vas allows it to more closely approach an EBS alignment in
that box).
The 1503 has more power handling and displacement, so has a good deal more potential output with
more power, but you'd also have to be careful about driving your PRs into overexcursion were you to
substitute a 1503. As Thomas has also pointed out, these high-inductance woofers require some eq
in the upper reaches top pull down a peak, but I think you've already got the eq covered.
Thanks Jack much appreciated!
So do you think it would worth the swap for me.
I'm looking for the most output,below 30hz!
Also with the Tempest,the Pr's not even close to reach it's max excursion,so I think there is room for the Blueprint,if it's worth to swap it out,say if it's 3db or more @20hz.
"You Hungarians always disagree"
The Krell MRS klone is probably going to require a Linkwitz Transform circuit given the very small cabinet. I'll just use a Marchand Bassis for initial testing.
Thomas, once you establish the performance you like via the Bassis, what would the advantage be of substituting a LT circuit for it? What improvement would a "real" LT crcuit provide, or what drawback would there be to using the Bassis, if any?
And to take that a step further, how about just using a regular parametric EQ (like BFD)?
Andrew
The bassis is a TL with a single band of EQ. The only advantage of a dedicated LT over the bassis is cost savings.
Thank you, Thomas, that's the way I think of the Bassis.
Jack,
Pat emailed me late last night. My CC was charged Friday, my 1803 should ship today, and I should have it by this Friday!
Brian
Brian,
I received my FedEx tracking number today, I expect the 1803 next Wed. The shipping weight is 74lbs.
