Stryke AV12 in sealed box vs. Peerless XLS12 with PR ?
Discussion in 'Archived Threads 2001-2004' started by Mikael Jonsson, Feb 23, 2003.
  1. Mikael Jonsson
    Mikael Jonsson Auditioning
    Feb 22, 2003
    5
    Has anyone had the chance to listen to both, and if you have, please comment, because I´m going to go with either one without any chance to listen to them.
    I´ve read a lot here about the AV12, and it seems to be a great driver, planning to have it in a sealed box 45-50 liters and powering it with Rythmicaudio´s 350w plate-amp.
    (Can you compare this to any comercial sub?)
    The XLS12 would be in a 40 liter box with one PR, powered with same amp as above.
    Which would give the most bang for the buck, I´m in Sweden so importing the AV12 will be almost the same price as buying the XLS12+PR locally.
    I´m using my sub mostly for movies.
    Patiently awaiting you´re wise comments, Mikael [​IMG]
  2. Mikael Jonsson
    Feb 22, 2003
    5
    Come on guys, someone must´ve heard them.....or not?
  3. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    You'll have a tough time finding someone who's actually heard them both. I'd go with the sealed AV12 myself. I've got one in just over 1 ft^3 with an even smaller amp and it's great.
  4. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    Yea, that XLS doesn't look like it'll cut the mustard for HT duty, even with a PR.
    Pete
  5. David Lorenzo
    David Lorenzo Stunt Coordinator
    Dec 12, 2002
    198
    Hey Jack
    How's the response of your sealed AV12
  6. Jack Gilvey
    Mar 13, 1999
    4,948
    Hi David,
    I'm using an Adire AVA250 amp, the driver is in just over 1 ft^3 fairly well stuffed. I'm using a Linkwitz transform circuit to boost the low end so it's flat to below 20hz in my room but, even without, it goes extremely deep and sounds great doing it.
