Stryke AV12/15 le
Discussion in 'Archived Threads 2001-2004' started by LeroyR, Feb 2, 2003.
  1. LeroyR
    LeroyR Auditioning
    Feb 2, 2003
    I am interested in purchasing Stryke's av12 or av15, but I would like more info the inductance (le) parameters for the respective drivers (mh per voicecoil)?
    Thanks.
  2. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    AV12 T/S
    Fs: 21Hz
    Qms: 4.41
    Qes: .399
    Qts: .366
    Vas: 88 L
    Re: 2.97 ohm
    Z: 4 ohm
    BL: 15 Tm
    Cms: .25 mm/N
    Mms: 228 g
    Pe: 500W
    1W/1m: 85.5dB
    2.83V: 89.5dB
    Xmax: 23 mm
    Xsus: 30 mm
    Sd: 498 sq cm
    Vd: 2.33 L
    AV15 T/S
    Fs: 19.7 Hz
    Qms: 4.71
    Qes: .399
    Qts: .368
    Vas: 228 L
    Re: 2.97 ohm
    Z: 4 ohm
    BL: 15.5 Tm
    Cms: .25 mm/N
    Mms: 260 g
    Pe: 500W
    1W/1m: 88.5dB
    2.83V: 92.5dB
    Xmax: 23 mm
    Xsus: 30 mm
    Sd: 802 sq cm
    Vd: 3.8 L
  3. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
    Brett,
    Maybe I'm missing it, but how does that help him? I don't see the Le listed for the voice coils there.
    Seth
  4. Le is about 1.5mH (per coil) iirc.
  5. Chris Carswell
    Chris Carswell Supporting Actor
    Mar 5, 2002
    598
    Didn't they screw up (not that I mind) & build them with a single 4ohm coil?
    If they do come in DVC, Wouldn't 3mh be a bit on the high side?
  6. There was a mix up and some of the AV's were shipped SVC. I think john will be shipping out some DVCs too
    3mH is not too high considering that the HE15 and BPD 03's which "were" the high excursion kings had inductances around 12mH.
    A lot of other subwoofer have Le's around 2-2.5, but they also have xmax's around 16mm
    The 3mh on the AV is with the coils in series (2ohms per coil).
  7. Chris Carswell
    Mar 5, 2002
    598
    Wow, didn't think they went that high!!! I've been desensitized since I've been playing with 5" & 7" SS & Focal drivers. When I get a chance I'll do some sims on diff subs - pop in Le of 15mH (in place of 1.5mH) and see what happens (out comes that inductance hump in the FR) [​IMG]
    Thanks Gomer
  8. Ryan Hawke
    Ryan Hawke Agent
    Jul 10, 2001
    45
    Are these shipping yet?? Thanks to anyone who knows!
    --Ryan
  9. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    i was told on my last update was the first 2 weeks of theis month.
