Stryke audio (1 Viewer)
Jonathan T
This question is about a stryke audio product, not a DIY project. What is the IV series woofer?
And will/does stryke make any car audio subwoofers? Finding a sub with a similar displacement to price ratio is pretty much impossible in car audio.
Robert_J
Mississippi
He makes subs that are suitable for both home theater and car audio. The AV servies is an awsome sub for the car.
-Robert
Jonathan T
I know the AV can be used in cars, the only problem is that they require a huge box in comparison to ther 12s. I realize they can displace a lot more, but I don't need that kind of output in my car.
Robert_J
Mississippi
Huge box? The AV12 requires a 1^3ft box to get a Qts of .7. The AV15 requires a 2.5^3ft box for the same. If you run sims on some "real" car subs, you will see that their .5^3ft. recommendations are really giving you a Qts near 1.
-Robert
brettjv
