chris rick
- Sep 20, 1999
Wow this is getting annoying! Ever since I hooked up the VGA cables to my projector, I get this issue where the screen will go blank for about a half second every now and then...sometimes it is very frequent and other times it takes awhile for it to occur. I don't get it, and I did NOT have this problem when I was using component cables. I checked everything, the unit has plenty of breathing room as does the power supply.
This is the first time I've used the PC input on my projector (Panny), so is there something I have to do as far as syncing it or something? This is so frustrating especially given how absolutely gorgeous the games look.
As an aside, I had to center the image severely using the h position and moving the image all the way to the right. What about the "dot clock" etc settings in the menu for pc input? Any help would be appreciated guys. Thanks!
