Strange Star Trek VI copy
Discussion in 'DVD' started by Jason*C, Jan 27, 2004.
  1. Jason*C
    Jason*C Extra
    Oct 26, 2003
    21
    Hey guys I just went to a Fred Meyers early today and I bought a strange copy of Star Trek VI. The case was white with a pink barcode in the back. Inside there was no insert and just the two dvds.
    Is this some kind of screener copy?
    Edit:
    I also noticed that the Excelsior on the second dvd is upside down.
  2. Todd Phillips
    Todd Phillips Second Unit
    Oct 15, 2000
    279
  3. Stephen_J_H
    Stephen_J_H All Things Film Junkie
    Jul 30, 2003
    5,590
    872
    9,110
    North of the 49th
    Stephen J. Hill
    If you guys have no serious issues with bilingual packaging, the Canadian version of Star Trek VI:CE comes in a black case with a white barcode, and the bilingual packaging is not nearly as invasive as an Alliance Atlantis release.
  4. CraigF
    CraigF Cinematographer
    Nov 20, 2002
    2,666
    122
    4,110
    Toronto area, Canada
    Craig
    Not ALL Canadian copies, mine is white, only difference with U.S. version is the cover insert. It's pretty easy to get a BLACK keepcase, if you really care, I mean you can't even see a half square inch of white (or black) when the case is on a shelf, and the spines of the series aren't exactly consistent anyway. Now if it was a blue or bronze or gold etc. case and I didn't get that, then I might be annoyed a bit. What I don't like about the case is its cheapness, it's very warped and doesn't close properly, I have had the same problem with similar cases from Criterion. But then the price of this was cheap too, and as long as the disc is protected by whatever it's in, I'm OK.
