1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
strange problem...I'm watching Boomtown in hd and it was filling my entire widescreen
Discussion in 'TV Shows' started by Chris Hicks, Sep 26, 2003.
  1. Chris Hicks
    Chris Hicks Stunt Coordinator
    Nov 1, 2000
    187
    then during a commercial I swiitched inputs for a minute. after I switched back and the show started the pic now has black bars on all 4 sides of the pic. what happened?
  2. Dave Scarpa
    Dave Scarpa Producer
    Apr 8, 1999
    5,351
    59
    David Scarpa
    Yeah it seemes like NBC flubbed up.
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,727
    470
    Well, more likely the local NBC affiliate flubbed up. The more HDTV broadcasts you watch, you more you'll notice it on transitions to commercials (usually in 4:3 aspect ratio), and when the show comes back, someone forgets to flip on the switch for the HDTV feed.
  4. Bryan X
    Bryan X Producer
    Feb 10, 2003
    3,469
    3
    I've had the problem where my local NBC affiliate forgets to 'flip the switch' at all. Example: During Friday's MissMatch the show started in Standard Definition. I had to call the station and tell them to switch to the HDTV feed. Unfortunately the show was nearly over before they got it switched (when I called, I was told the guys in engineering were on break). I've had to call the station on a number of occasions for this.
    I just emailed the general manager to complain, so hopefully that will put some incentive for them to pay more attention.
  5. ScottNJ
    ScottNJ Auditioning
    Sep 28, 2003
    9
    I had the same problem with Boomtown about halfway through the show. The HDTV just went away leaving letterboxed 4:3 ratio. [​IMG]
  6. NateM.
    NateM. Auditioning
    Aug 17, 2003
    5
    I have also experienced that same problem, but most often during The Tonight Show w/ Jay Leno. It's very annoying![​IMG]
  7. DaveBB
    DaveBB Supporting Actor
    May 24, 1999
    788
    If you go the the HDTV programming forum at avsforum.com it seems like tons of people are having problems with HD from NBC. Sounds like these problems are network based and not at the local affiliate.
