Str Vz555es And Parasound Hca2205at
Discussion in 'Archived Threads 2001-2004' started by Arby, Feb 28, 2003.
  1. Arby
    Arby Auditioning
    Oct 21, 2002
    8
    Just bought these new VZ555ES AND HCA2205AT.
    Need help from ES gurus pls. Parasound require only 15mA 12v dc to trigger on. I have an old 12v 300mA and another 12v 500mA used as a cellphone charger. Will any of these work if i connect the power line of the converter at the back of the ES and 12v dc out to the trigger input of the Parasound? Which one is suitable? Isnt this too much? No overload or overheating will happen?
    My manual for the ES is written in Japanese. Is there any compatible english manual for this model online for download?
  2. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    Arby,
    Sorry...can't help with the manual. But either of the 12V converters should work. The 15mA is just the minimum sensitivity. To use my 855A, I had to use an extension cord into my H/K receiver as the power head with polarized plugs covered both the switched and unswitched outlets.
  3. Arby
    Arby Auditioning
    Oct 21, 2002
    8
    Thanks Paul. It now triggers the amp and works great. I was looking into the manual of DA5ES and was able to partly set up my VZ555ES. Hope it does not make big difference in the set up with its other features.
