DarrylM
- Jan 4, 2003
Which is actually what makes them valuable, as far as I am concerned. Lab tests push the performance envelope of a product, so you can see how it holds up under demanding conditions and not just casual listening. They also provide an objective, unbiased benchmarking process to compare multiple products. After all, how often can you take every receiver you want to audition home for an A/B comparison?
Personally, I don't feel the need to listen to a receiver if I know that it delivers reference level power with a flat frequency response down to a reasonable load (impedance) with a minimum of noise, which is something a thorough bench test can tell me. I don't want coloration in any of the components of my system, so I am not out for a "bright this" to match my "warm that." I don't want to have to mix and match components and that sort of thing. I just want to hear my CDs and DVDs as the recording and mastering engineers intended. But that's just me, and I realize that others feel differently.
