Colin Banfield
- Sep 23, 2002
This might be a silly question but...do all of the internal processing options in the STR-DA4ES(bass management, time delay settings etc.) work through the multichannel pre-outs?
This might be a silly question but...do all of the internal processing options in the STR-DA4ES(bass management, time delay settings etc.) work through the multichannel pre-outs?Absolutely.
This receiver can be used as a pre/pro (preamp/processor) with external amplification if that is what you are asking. The sound coming out of the pre-amp outputs is exactly what is fed into the internal power amplifiers.
Now, the opposite is not true, that is, you get no controls of any kind except for volume and left/right balance when using the 5.1 or 7.1 inputs. No EQ, no soundfields, no bass management, no level or delay controls. Nada. It is assumed that all controls and processing is done externally. This is the only way to preserve the high quality of DVD-audio or SACD sources connected to these inputs.
I happen to be from the school of thought that believes that an option for bass management, etc. for these inputs (D/A) is a better evil than none at all.I would tend to agree. Despite the fact that the 4ES already has 24/96 D/A's for all channels, it would need to have a set of (expensive) 24/96 or at least 24/48 A/D's in order to do this. Anything less wouldn't cut it. My SACD player (SCD-CE775) does do full bass management and level adjustment, but does not have any kind of delay settings. I had wanted to buy a DVD/SACD player instead, but it lacked bass management, so I had to stick with the SACD-only unit. The only thing holding me back from buying a DVD-audio player right now is the relative lack of players with bass management.
It is interesting to note that if you have the sub output turned off in the setup of the 4ES, then the sub channel of the multi-channel inputs is mixed into the front left and right channels (at -3 dB each channel). This is done in the analog domain.
