Stop the rattling!
Discussion in 'Speakers & Subwoofers' started by BryanMM, Jul 18, 2004.
  1. BryanMM
    BryanMM Extra
    Jul 4, 2004
    18
    I got my SVS PB1 ISD and I put it in a corner of my room. It's at about halfway gain. Now the problem is the receiver is just to the side of it on a table and when the bass is running, it shakes and rattles stuff and making this annoying sound. I narrowed it down to the metal gratings on the top of the receiver.
    I tried putting some soft material underneath, but it still does it. Does anyone have any suggestions? I can't move the unit as I have no other place to put it. (And I would have to get new cables which I no money for)
  2. Kevin Patterson
    Kevin Patterson Stunt Coordinator
    Jan 14, 2004
    61
    try putting some weight on it without blocking the vents. Also try putting some thick tape or something of the sort undernethe the metal just to dampn the vibrations.
  3. Rutgar
    Rutgar Second Unit
    Jan 17, 2004
    495
