Still working on my Tempest Proyect (preliminary graph response)
Discussion in 'Archived Threads 2001-2004' started by Manuel Delaflor, Aug 20, 2002.
  1. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    Hi all.
    I have been working for about three weeks on my Tempest Sonosub. The sonotube is 18" and 54" tall (I discounted here the MDF's for the driver and the port). My calculations are 225L tuned to 20.50 using a 6" port diameter with a length of 19.7". According to UNIBOX this would give an F3 of 21Hz, which is apparently the case.
    At the time I ordered the Tempest I ordered a calibrated mic also, but the guy who told me about it resulted to be a fraud. So I don't have the correct tool. Anyway, using my SPL Meter I get this graph at my listening position.
    Frequency Response from 10 to 100Hz at listening position
    This the raw data using the SPL Meter as a mic, without calibration. I know it is tunned to 21Hz, but I don't like the fast roll-off after that precise point. Perhaps the SPL Meter has something to do about it, or perhaps my room (which resonate between 40Hz and 50Hz by the way).
    Anyway guys, what do you think about it? Should I tune it lower? I want to get around 16Hz at decent SPL's if possible.
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    It looks fine. Have you actually listened to it playing DVD LFE audio tracks, or CD music tracks?
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    If you want decent 16hz output, tune it lower [​IMG] Although don't let the port get any longer than 30".
    Have you tried adding a correction file for the RS meter into the program you're using? The RS meter rolls off pretty heavily in the last octave.
  4. Manuel Delaflor
    May 25, 2001
    657
    Patrick,
    I have tested it with test tones I have made myself, and with lots of MP3's that are around the net to test subwoofers. The baddest bass is on a certain track that have the tyrannosaurus, this track has LOTS of energy below 20Hz.
    Dustin,
    I wonder about your recommendation for the port length? and about how many dB at 20's 30's I will lose by tuning that low? The curves on Unibox shows a dramatic fall.
    By the way, I assume the graph is loading ok. Oh, one thing more. I have discovered that if I open a closet I have in the room I can boost the output several dB's from 25Hz and up, but totally destroy any output below that level. It is like having two different subs! [​IMG]
  5. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    Well, you can measure all day, or actually enjoy the fruits of your Manuel labor! [​IMG]
  6. Manuel Delaflor
    May 25, 2001
    657
    Patrick, Lol
    To all:
    I just visited this link again:
    All mighty comercial subs
    And Im Very Very happy to see that my graph (even using an SPL Meter as a mic) compares favorably to all those state of the art subwoofers!
    [​IMG] [​IMG] [​IMG]
  7. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Pat,
    GA Tech has produced many an engineer, but I imagine very few comedians! [​IMG]
    BTW, I got an email at work from someone titled "New Manuel" for an application we use. I couldn't help but inform him that Manuel was a small Mexican boy! [​IMG]
  8. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    My goodness - five thousand comedians out of work and engineers are trying to be funny. Tsk, tsk, tsk. What's the world coming to?
    Brian, get back out in the shop - you've got lots of MDF dust-making labor ahead of you.[​IMG]
  9. Manuel Delaflor
    May 25, 2001
    657
    Guys guys
    jokes aside...
    what about my graph? [​IMG]
    This weekend I will lower the tuning point and see the changes on the response. If there is enough interest I will upload some distortion graphs also.
  10. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    Lowering the tune will drag the response down a bit from 30Hz down to under 20Hz.
