Sticking a Tower in a HTPC Case
Discussion in 'Computers' started by Grant B, Apr 25, 2004.
  1. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    Seems simple enough but there is always somethings that makes it hard. Anyone take a normal tower PC and stick it in a HTPC case? What about the PS and cabling....just switch it to the new case?
    My computer is a Sony Viao RX series if that matters
    Grant
  2. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    If both cases are the same form factor, ATX being the most common, then it should work. But companies like Dell, Gateway, HP, Sony sometimes use proprietary setups as well that make this difficult, if not impossible. They don't want the PC upgrade friendly, they want you to buy a new one. Really hard to say until you attempt it.
  3. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    Is there a way to find out...size, marking etcif it's standard?
  4. Chris
    Chris Lead Actor
    Jul 4, 1997
    6,788
    There are going to be two formats you should check.. Microatx & ATX. Now, if your MB in that VIAO is a microATX, then it will have no more then 3 total slots normally (or 4 if a shared AGP) if it's a full form factor (larger board) you need to know as many HTPC cases are geared at microATX boards. A lot of the RX series seem to be full ATX, not micro.
  5. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    thanks!
