Stereo Receivers/No digital in?
Discussion in 'AV Receivers' started by Jonathan Larson, Apr 3, 2004.
  1. Jonathan Larson
    Mar 12, 2004
    17
    Hey guys,
    I was wondering why stereo receivers these days don't have a digital in option? Is there a big difference between digital and analog when it comes to listening to music off of a CD?
  2. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    When you listen to music from a CD, you're ALWAYS listening in analog. The difference you're talking about is where the conversion from digital to analog takes place. The hardware/software that does this conversion is called a DAC (digital analog converter).
    If you use the analog outputs from a CDP (CD player), the DAC in the player did the conversion. If you use the digital output from the CDP, the receiver will be doing the conversion. Usually, it's a matter of comparing the sound of the two and going with whichever you like better. As Duke Ellington used to say “If it sounds good ..., then it IS good!”
  3. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    LIke Jeff said, it's to save $$$ by not having to add in the DACs into the receiver. There's really no need to have a digital input anyways since your Stereo Receiver can't do multichannel, and most CD players will have decent DACs in them. If you decide you need more, you can always buy a standalone DAC, use digital to connect your CDP to it, and then analog from it to the receiver.
  4. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    There no reason at all to have digital ins on a stereo reciever.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    I'm sure the thinking is, if you want multi-channel, you will buy an AVR with digital inputs (and/or M/C analog inputs) and power for multiple speakers, not a stereo receiver.
  6. Sathyan
    Sathyan Second Unit
    Jun 17, 2002
    298
