Cliff B
- Mar 21, 2001
Hi all,
I have to replace my old receiver which has bitten the dust. I've got a pair of speakers that I plan on using (Yamaha NS10s) but I'm unsure of what wattage on the receiver would be appropriate.
The specs on the speakers are as follows:
Power Capacity:
Program: 60 watts
Max: 120 watts
Nominal Impedance
8 ohms
Any suggestions on what power rating would be best for the receiver? 100 watts/channel? More? Less?
BTW: I'm not really looking for a particular manufacturer. That will be determined later. I just want to make sure that I've got a receiver that matches my speakers properly without doing any damage to one or the other.
Many thanks!
Power Capacity:
Program: 60 watts
Max: 120 watts
Nominal Impedance
8 ohms
Many thanks!
