jeff peterson
- Nov 29, 1998
I got my 1124 from www.lentines.com for $129
5) Measure speaker distance exactly for 5.1 speaker setup
Bruce, could you go into a little more detail as to how you perform this measurement? How do you direct the test signal to the center and surround channels? Also, how do you calibrate ETF so it displays the actual dB level instead of the graph just topping out at 100dB?
So far, I've only used ETF to EQ my SV subs with a Rane PE-17 EQ. What a difference, the subs were great before, now their just outrageous! Then the extra PC I was using in the theater room had to go to a new owner. I haven't be able to use ETF for several weeks. All I need is a cheap ATX case and I can assemble a dedicated ETF PC with some leftover parts I have laying around. Then I can start playing with ETF again.
Thanks to everyone who has posted their experiences with ETF. It's a huge help for us slow learners!
Bruce
did you set your recording controls to just Line In?
No, not at first. I didn't even know there were 2 mixers (a playback and a recording mixer) until I ran into these difficulties with ETF. Somewhere along the line between emails to ETF, I discovered the recording mixer. :b
But I also found another problem. I was using my SB Live! value card's black jack (line-out #2) and the light blue line-in. Once I got the recording mixer set properly, I found the black jack did not work (got -57 dB/-58 dB rec levels). When I changed the line-out to the lime jack (line-out #1) I got -2 dB on both left and right channels on the level check. And the broken test showed -57 dB/-58 dB for Ch1 and 2.
I think I'm in business now.
Thanks to all for your patience and advice. I have got to find a way to work this software into the budget. This is too good to pass up.
Notice: a new software testing company is being setup called Idiotproof Software Testing Services. Email me for details...
It displays a popup window that shows the distance in meters and feet from that speaker to the microphone (at listening position) and also shows the delay time in ms (milliseconds). Accuracy is to 0.05 ms.
This may be a problem when running long cables into another room. I was getting exaggerated distances, and I think it's because of the length of cable. I'm going to try to add an equal length of cable in between the two lines that loop between the soundcards input and output jacks to see if that straightens this out.
Pete
