Static Duster Danger....?
Discussion in 'Beginners, General Questions' started by Vader, Apr 30, 2004.
  1. Vader
    Vader Supporting Actor
    Mar 19, 1999
    810
    24
    Derek
    Hi all,
    I think this may be yet another manifestation of my manic paranoia, but I want to be sure. I have been using a static duster (sort-of a generic Swiffer) to dust my components, and never had a problem. When I dusted today I noticed that the static duster reset an LCD digital clock as I was dusting it. I know that the charge is several thousand times less powerful than a door shock (just enough to pick up loose dust), but I am worried that a residual charge could be building up on the chasis of my amp (& DVD player, LD Player, etc). Am I worrying over nothing? Thanks in advance!
    Derek
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    So yer paranoid you say, eh?
    No, there's little to no chance of a static charge building up. Next time spray a little Static Guard available at you local supermarket on the Swiffer.
    This has been another helpful hint from the Heloise Audio collection.
  3. Vader
    Mar 19, 1999
    810
    24
    Derek
    Thanks, Chu.....:)
    After some consideration, I concluded that it would be bad if any electrical components were touching the chassis anyway (otherwise that would give a short). I have not used my physics training in a while, but if memory serves the electric field inside a hollow conductor (like the metal chassis of my amp) is zero anyway. So, unless I choose to open up the chassis and dust the components directly with the static duster ("in the case of an actual synaptic connection, you will be instructed to..."), I think I am safe (knock on wood).
    Or am I all wet here? Has anybody ever fried anything by using static-based dusting?
    Derek
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    I think the worse you can get is a static discharge, which, depending upon what you've got in your system, could certainly wreak some havoc with internal microprocessors, clocks, memory modules, eproms, eeproms, etc. After all, it's more than a few volts.
    If you've ever worked on your computer then you know that you're always advised to ground yourself by touching a metal object to dissipate any charge that your body may have (trashing a bios is no fun...neither's the CPU) and in fact, careful individuals will use a grounding strap of some sort. The same caveats to my mind apply here. Winter weather, due to the low humidity, will of course make matters worse.
