Starting my DIY Silver Screen .... Getting there.
Discussion in 'Home Theater Projects' started by MikeMon, Aug 28, 2005.
  1. MikeMon
    MikeMon Stunt Coordinator
    Feb 8, 2005
    77
    Thought I would show you guys my screen progress... I am trying to fix some bad dry wall work, if I only could get the nack of it... I have several more to fix but I will get to those later on.
    [​IMG]
    [​IMG]
    [​IMG]
    So you can see my progress............ This is where I am tonight..
    [​IMG]
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Drywall finishing takes a lot of experience to make it look good. My screen wall had too many problems, so I painted a sheet of 1/2" MDF and hung it on the wall. Good luck.
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    What paint are you using?
  4. MikeMon
    Feb 8, 2005
    77
    UPW silver screen and UPW Hi-Gloss
  5. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    Have you put on the high gloss yet? I am a little concerned about hot spotting, glare, and/or the affect of room ambient light on the screen with a glossy finish.
  6. MikeMon
    Feb 8, 2005
    77
    well the high gloss is going to work as the primer in this situation it will be covered by 2 coats of SS (flat). I will post back after the hi gloss has been put on. Should be later tonight or in the morning.
