Omar, In a resounding chant from the crowd "Stay away from Bose."
Bose is definately bad news. There's much better to be had for the same money.
If you were interested in Bose for the small speakers, do a search for "Bose" on the forum and you'll turn up dozens of suggestions (as well as rants about why Bose is bad) for alternatives to Bose that have similar size speakers.
If you were interested in Bose because of the name then you probably don't have any set requirements for type of speaker (floor standing, bookshelf, sattelite). The first thing to do is to work out just what your budget is.
After that, I would decide on speakers before anything else. Speakers will have a much more profound control over the sound of your system than anything else you buy.
The general rule of thumb is to spend somewhere around 60% percent of your budget on speakers. With budget constraints figured out, find all the audio dealers within driving distance of you. Spend an aweful lot of time listening and deciding what speakers sound the best to you.
Once you've settled on speakers, you'll have to shop around for a receiver, dvd player and any other components you may want or need. But I'll leave them to their proper forums.
This should be enough to get you on your way. Don't feel rushed in picking speakers. They'll likely be with you a long time and it's important that you get what sounds best to you.
