Starship Troopers reg. 2
Discussion in 'Archived Threads 2001-2004' started by Sune Svanekier, Jan 21, 2002.
  1. Sune Svanekier
    Sune Svanekier Auditioning
    Jan 15, 2002
    3
    Buying DVDs in Europe you have to consider not only the differences between regions 1, 2, 3 etc. but also the differences within the same region - code 2 in this example.
    DVDs manufactured in the UK tend to be cut, i.e. material that has been censored (mostly due to graphic violence) from the theatrical releases will also be excised from the DVDs. Other parts of Europe, Denmark, where I live, for instance, don't censor films like the UK does, and the DVDs produced in Denmark won't be cut, so one has to be careful when one is scouting for DVDs.
    I bought Starship Troopers, happy that there was finally a region 2 version with the same extras as the old laserdisc and with Danish subtitles. Later I discovered that this was a UK DVD, and I noticed that the running time was shorter on this than on the code 1-disc and (as far as I remember) on Danish code 2-discs.
    This might mean that the copy I have has been censored, and it is very annoying. I don't know the film that well and am not able to tell if it has been cut.
    Does anybody know this? And does anybody know about any other discs with the same problem? (I know of the Lethal Weapons-series).
    Yours' sincerely,
    Sune Svanekier
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    The UK censors a ton of ludicrous things. Headbutts (WHY?) until recently nunchucks, hot wiring cars, just little stupid things that only piss people off. Usually it's just a second or 2 of violence, which ST has in spades
  3. Didier
    Didier Agent
    Jul 9, 2001
    28
    In the early days of DVD, a few French DVD releases were cut the same as the U-K releases. This was heavily criticized here, and now nearly all French DVD releases are totally uncunt.
    Didier.
  4. Thomas Agermose
    Thomas Agermose Stunt Coordinator
    Jan 22, 2002
    94
    Thomas Agermose Jensen
    Hi Sune. Nice to see a fellow dane in here.
    If you go to www.bbfc.co.uk and search for Starship Troopers
    you will notice that it was not cut by the BBFC.
    At least some of the discrepancy on the running time can
    be explained by what is known as PAL speedup.
    This means that all movies in PAL format will run 4% faster than their theatrical (and NTSC) counterparts.
    Try and multiply the running time of your old LD by 0.96, and see if you get about the same time as the DVD.
    One more thing. Some studios actually release more than one version of the DVD, for different parts of Europe.
    If you look on the disc sometimes it will say D1, D2, D3 or D4. D1 is UK discs, D4 is Europe incl. UK discs. D2 and D3 are european discs.
  5. Bob Partovi
    Bob Partovi Stunt Coordinator
    Mar 14, 2001
    137
    i'm so sick of censoring. here in the us movies don't get censored by the government, only by the movie studios so they can fit a demograhic(pearl harbor for teens was cut from R). I don't get why the UK is so strict with censorship and a country like japan isn't
  6. Ted Todorov
    Ted Todorov Cinematographer
    Aug 17, 2000
    2,965
    24
  7. Mike H
    Mike H Stunt Coordinator
    May 10, 1999
    76
    Then how was Requiem for a Dream released? It is unrated.
    Mike
  8. Greg_D_R
    Greg_D_R Stunt Coordinator
    Mar 11, 2001
    221
    4
  9. Ted Todorov
    Aug 17, 2000
    2,965
    24
