Standing wave - get 2 subs, or treat the room?
Discussion in 'Archived Threads 2001-2004' started by Colin Dunn, Aug 12, 2001.
  1. Colin Dunn
    Colin Dunn Supporting Actor
    Oct 10, 1998
    724
    6
    My HT room is a slightly L-shaped. The front portion is about 17'W x 16'L x 8'H. The back portion is 20'W x 12'L x 8'H. The result is a room that's 17'x28'x8', with some extra width in the back where I've put my DVD racks.
    My subwoofer is a Velodyne FSR-15 - a servo-controlled 15" model.
    This room suffers from a standing wave. There is a narrow frequency range that is strongly reinforced by the room, making it probably 10dB louder than it 'should' be. I tried moving the sub around, but that did nothing about the standing wave.
    Would going to a 2-sub system (excuse to sell a Velodyne and upgrade to dual SVS subs) cause some partial cancellation that would even out the in-room response? Or should I forego the hardware upgrade and head over to the "Building a Home Theater" section to find out about room treatments?
    Colin Dunn
  2. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    You could get something like a Behringer Feedback Destroyer and equalize the sub to eliminate that peak too? Cheapest option of all, I think, at less than $200 (I think).
    /Kimmo
  3. Steve_D
    Steve_D Second Unit
    Nov 28, 1999
    299
    My ART 351 has my L shaped room down to +-6 db, down from +-16 db.
    EDIT - UPDATE
    After more experimentation, I'm down to +-4 db from 20 HZ to 85HZ, the crossover being at 80.
    http://www.sdiver.org
    [Edited last by Steve_D on August 12, 2001 at 03:34 PM]
    [Edited last by Steve_D on August 12, 2001 at 11:12 PM]
  4. Stephen Dodds
    Stephen Dodds Second Unit
    Aug 29, 1998
    354
    Yep, EQ that sucker.
    And upgrade anyway.
    [​IMG]
    Steve
    Steve's Toys
