Spring clip wiring advice sought (1 Viewer)
Timothy_A.
Hi. Any advice on how to make 12 or 14g bare wire fit into a spring clip terminal? I pulled about 1/2" insulation off the wire and twisted it tight but it seems to have difficulty going in the clip hole and the tight twist ends up looking like a mini-brillo pad ; )
I notice some wires have a solder coating at the end to make them effectively one wire. What is the simple approach to doing that?
Thanks!
Jim FC
The coating you're referring to is created by a process called "tinning." You can get a soldering iron and a thing of solder from Radio Shack for $15 and do it yourself... you just let the iron heat up, touch it to the end of the stripped copper and let that heat up for a sec, and then touch the solder to the copper (not the iron!). The solder seeps into the copper and keeps the ends from fraying and shorting out.
ChewyWaffles
