splitting receiver to two subwoofers?
Discussion in 'Speakers' started by Andrew O'Brien, Dec 26, 2003.
  1. Andrew O'Brien
    Andrew O'Brien Stunt Coordinator
    May 27, 2002
    97
    I'm thinking about buying a subwwofer and then comparing it at home to my passive sub-woofer, will return if not as good. Any nasty outcomes that can occur if I split the signal from the receiver to the two subwoofers using a simple Y connector ?
    I'll use a separate receiver to power the passive subwoofer.
    Andy.
  2. AxelKro
    AxelKro Stunt Coordinator
    Dec 24, 2003
    102
    Hi Andy,
    no, I wouldn't expect any. Using a Y-Cable is the standard connection if two pieces of gear have to be connected to one source.
    Cheers,
    Axel
  3. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    No problem at all Andrew. If you plan on trying out both subs individually in the same location why split though? You also can split farther down line if it will save you some $$ in cable costs.
  4. Lanny_B
    Lanny_B Second Unit
    Nov 24, 2001
    280
    I'm thinking about getting a couple subwoofers, and thought I might order a splitter while I'm at it, but the ones I see are CATV Y Splitters, so I'm thinking that's probably not right.
    Is this the kind of part I'm needing to buy? Or how do I distinguish which one is the right type to work with subwoofers?
  5. TanT
    TanT Stunt Coordinator
    Dec 17, 2002
    135
