splitting 5.1 channel inputs
Discussion in 'Archived Threads 2001-2004' started by Kevin T, Oct 27, 2001.
  1. Kevin T
    Kevin T Screenwriter
    Jul 12, 2001
    1,402
    i was browsing the ta-p9000es thread a second ago and i began to wonder...$450 is a lot of money for a switcher. couldn't you just use a y-splitter type cable on each of the 6 rca inputs on the 5.1 input? wouldn't this allow you to connect both multi-channel dvd-a and sacd to the same input? i don't see why it wouldn't work. is there really that big of a sacrifice in the sound quality? anybody who has done this, i'd be interested to know as i'm sure i'll end up with a dvd-a and a sacd player one day and the outlaw 950 only has one set of 5.1 inputs. thanks for any info you can provide.
    kevin t
  2. brucek
    brucek Second Unit
    Dec 29, 1998
    335
    Kevin,
    The simple answer is no.
    You would be effectively shorting the outputs of the two (low output impedance) sources together. Not allowed.
    Even if only one of the devices is "powered on" at a time, the outputs are still shorted together.....
    brucek
  3. Stacy Huff
    Stacy Huff Second Unit
    Jul 13, 1999
    378
    Check the AV forum for a possible solution for using DVD-A and SACD on a processor with only 5.1 input.
  4. Jah-Wren Ryel
    Jah-Wren Ryel Stunt Coordinator
    Jun 7, 2000
    131
    Stacy - could you be a little more specific on where to look? A link would be very helpful.
  5. Kevin T
    Jul 12, 2001
    1,402
    would you still be shorting the inputs if you used a t-adaptor like this:
    [​IMG]
    kevin t
  6. Stacy Huff
    Jul 13, 1999
    378
  7. brucek
    brucek Second Unit
    Dec 29, 1998
    335
    Kevin,
    That is a "Y" splitter you have shown a picture of. Sorry, you can't use that in this application.
    brucek
