JoseEduardo
- Jan 24, 2002
I just got this game, it is great so far but is there a special trick to do when trying to open a door with the lock picks??? I don't get it, I can not make the damn thing work!!! :frowning:
Re: Sticky Cameras
My friend found out you can use them on an enemy's head to knock them out and then just pick the camera back up. Infinite non-lethal ammoReally? I swear I tried that, but the camera just bounced off the guy and landed on the ground (and the target didn't even notice). I'll have to try that again when I get a chance...
I find that if you have a disposable lock, feel free to use it. I don't think there is one place in the game where you HAVE to use it.There are at least a couple of places as suggested above where the disposable pick is almost essential. If you aren't pressed for time use the manual method - it's easy to do once you're used to it. Save the disposables just in case.
