spl meter
Discussion in 'Archived Threads 2001-2004' started by Frank joe, Aug 10, 2002.
  1. Frank joe
    Frank joe Stunt Coordinator
    May 28, 2002
    155
    ok i tokk all your advice and stacked my subs .what a difference it made . but how do calibrate it with my spl meter?> do i use c weighting with slow response ??? and what db so i look for???? help?
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    What calibration disk do you have?
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
  4. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    I just bough my SPL, but I bought the digital, and I have seen that many use the analog, do you think both operate the same, or should I return it and get the analog?
    Pablo Abularach
  5. Jeffrey R
    Jeffrey R Stunt Coordinator
    Feb 5, 2002
    199
  6. Kirk Gunn
    Kirk Gunn Screenwriter
    Aug 16, 1999
    1,609
    I thought the analog popularity was the ease of reading an analog gauge during minor fluctuations. I could be wrong...
  7. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    I thought it was just because it cost half as much.
    Problem is where I am, they don't get the analog anymore, only the digital, so I had no choice.
  8. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    Same thing here. Just the digital. I bet they make more?
  9. Daniel J
    Daniel J Stunt Coordinator
    May 8, 2001
    186
    The digital is easier to use for quick, precise measuring (you see a number instead of a +/- level) and it's also more accurate- mostly because the analog needle isn't quite as fast as it needs to be. Digital is also supposedly more reliable, as there's no needle to break. (this info is second hand, from a pro sound web page, btw, but I trust it.)
    That said, analog meters are easier to see peaks on from across the room; but if you are going through the trouble of buying an SPL meter you should either have a friend help you take measurments, or conduct your tests in such a way that you can be at the meter.
    BTW, make sure to hold the meter at arm's length, or on a tripod if you have one.
    And yes, you should use C-weighing. it's about -8.5 dB @20Hz, IIRC, while A-weighing is significantly more.
    Neil- that chart is for C weighing, right?
