SPL meter questions
Discussion in 'Archived Threads 2001-2004' started by Jose G, Dec 5, 2002.
  1. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    I'm going to pick up the S&V and Stryke test disks for my sub and need a good meter to tweak my system. I'm I right that the Radio Shack meter is the one of choice for the money ($50.00)? Are there other suggestions?
    Does anyone know if the built in meter in the HK remote would work as a subtitute for the Radio Shack meter. The manual says I can use it to calibrate with a test disk, but has anyone ever done this with one?
  2. KurtJ
    KurtJ Stunt Coordinator
    Oct 14, 2002
    80
    Make sure you get the analog meter from Rat Shack; It's easier to see the needle move IMO.
    I would use the RS one. Plus, when you upgrade (and you will) you won't have to buy another meter.
