Spilled water on my keyboard
Discussion in 'Archived Threads 2001-2004' started by Thi Them, Jan 13, 2003.
  1. Thi Them
    Thi Them Producer
    Apr 20, 1999
    3,649
    I spilled a few tablespoons on it. I turned it upside down and shook it to drain as much of the water. Do you think it is still usable?
    ~T
  2. JasenP
    JasenP Screenwriter
    Dec 21, 1999
    1,280
    Kalamazoo, MI
    Jasen
    If its only water, I think you are in luck!
    I would turn it upside down and let it air dry (like in your dish rack) overnight, just to be sure.
  3. Ammon
    Ammon Stunt Coordinator
    Aug 26, 2002
    129
    You can pretty much sill water on any electonic device and you wont have to worry. As long as it was off when you spilled it and you let it dry thoroughly. Milk on the other hand would not be a good thing to spill.
  4. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    You could put it out in the sun for a day or two (take it in at night [​IMG] )
    //Ken
  5. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    You could put it out in the sun for a day or two (take it in at night )
    or when it's raining[​IMG]
    Brent
  6. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Take it apart and leave it overnight in your airing cupboard. Job done.
  7. Todd H
    Todd H Go Dawgs!
    May 27, 1999
    2,186
    92
    1,610
    Georgia
    Todd
    I've done the milk thing. I had to take the thing apart and clean it by hand. It took hours to finish.
  8. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    If you've got milk, coke or coffee stains in the keyboard, take it apart (i.e. remove the base, the membrane and the actual keyboard itself) and soak them for a few hours in hot soap water (washing-up liquid is fine). The stains literally rinse off afterware. Then place everything in the airing cupboar overnight, put back together and you've got a keyboard as good as the day it came out of it's wrapper.
