spiking subwoofer (1 Viewer)
Matt Dolejsi
Would i really benefit from spiking my HT Tempest, Its well built sealed, mid leaning to low Q design, I was looking into something interesting to add to the mirror black finish i have on it, and the dayton speaker spiking system looked alright. I wanted to know if anyone here has ever used something similar and if the imaging improved.
Chris Tsutsui
Personally I don't think spiking makes a noticeable difference, but I guess factors such as the type of floor and the weight of the sub may have to be taken into account.
If your sub is on a thick carpet with padding underneath, then spiking might be able to make the bass cleaner and perhaps more tight.
Something that will have a similar effect to spiking the sub is placing a heavy weight on top of the sub to add mass and reduce the vibrations of the sub.
Gabriel_Lam
I've tried those spikes before. I guess the results really depend on the sub you have. As to the actual build quality of the spikes, they're pretty good for the price.
Greg_R
Portland, OR
Greg
If your enclosure isn't vibrating then (based on my experience) it won't make much of a difference. Back in college, a roommate and I built a sub that would literally walk across the floor... spikes were required! Of course this was before I knew about proper enclosure design, bracing, etc. Spikes look cool though...
Logos1204
