Spikes on a downfiring sub (1 Viewer)
AlexKunec
"By rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system, it is possible to dramatically improve clarity, stereo imaging and tighten up the bass response" From PE.
Is this true? I don't quite understand the physics behind this.
My sub is downfiring on hardwood floor. Should I consider buying spikes. Also should I put something under the sub (Like a ceramic tile), so that the sound stays in the room, or would it be better just leave the sub firing into the hardwood?
On some high end yamaha subs (downfiring), they put some kind of a cone underneath the sub to direct the sound in all directions. Would that make much difference?
Robin Smith
I can't answer all your questions, but I will say, as I understand it, you should NOT use spikes on hardwood. The point of spikes is for use on carpet as it allows the footing of your sub/speaker to reach down through the squishy carpet and make contact with the solid subfloor.
With hardwood, this is not an issue. My PSB speakers came with both spikes and dense rubber semi-circle feet. The rubber feet were for use on hardwood (and would certainly do less damage) and the spikes were for carpet.
Can't explain the science behind it, just that that's the way I understand it. My guess is that for the best response you want a "solid" contact with the surface your speaker is sitting on, with hardwood, thats a given so the rubber feet are enough, but with contact you don't get that solid contact, thus the need for spikes.
Hope this helps.
Robin Smith
Ryan T
If you put your sub on a ceramic tile it will not stop the bass from being heard throughout the house. With hardwood floors your supposed to use rubber feet so you won't damage the wood. I think spiking the sub would make the problem worse. If you spike the sub to the floor your in a sense connecting it to the frame of the house. So when there is any movement in the sub cabinet it will shake the house also. If you have carpet between the sub and floor (with no spikes or feet) I think it would tend to dampen the vibrations from the sub cabinet and shake the foundation less. The only problem with having carpet and no spikes is it will "color" the sound some.
Ryan
Herman_tj
