Speedstep in XP
Discussion in 'Archived Threads 2001-2004' started by Adam Sanchez, Jan 18, 2002.
  1. Adam Sanchez
    Adam Sanchez Supporting Actor
    Oct 4, 1999
    903
    Is there any way to disable Speed Step for mobile Pentiums on laptops with Windows XP? It seems like XP does it automatically. I don't mind it much when I am using batteries, but when I have my Laptop plugged in at home, I want my Pentium III 1,000 to be running at that, and not lower. [​IMG]
  2. Brett_H
    Brett_H Second Unit
    Oct 3, 2001
    341
    Adam,
    I have no personal experience with XP or this processor, but I did a search on both Microsoft and Intel's support sites. Nothing came up from MS, but on Inte's site I found this article which might be of some use.
    Also be sure to read this article entitled "Troubleshooting Guide For Intel® SpeedStep™ Technology".
    Good luck!
    -Brett.
  3. Denward
    Denward Supporting Actor
    Feb 26, 2001
    552
    I have my XP laptop at home so I'm doing this from memory. There is an icon in the Control Panel (I think) that either says Speedstep and/or Power Management (or something like that). You can set different modes so that your computer operates differently depending on whether it's plugged in or running off of batteries. Similarly you can set how long the computer will sit dormant before taking power conservation measures such as turning off your display, hard drive, etc.
  4. Curtis Koenig
    Apr 14, 2000
    17
    XP gets the speedstep info from the hardware to turn this off you would have to use a utility from Intel. Windows just reads the info and can not change it.
  5. Adam Sanchez
    Oct 4, 1999
    903
    What utility from Intel do I need?
