I had seen this before. It's a cool comparison though so thanks for posting. It really underscores the need for level matching when comparing formats given the lower compression at least in this example.
Very interesting. An observation which I'm not sure has any bearing on the findings - is this analysis done using PCM tools? I'm assuming there is no DSD version of CoolEdit , so isn't the DSD audio being transcoded to PCM for purposes of wave and frequency analysis?
In any case, this is a visually compelling analysis, but I wonder if looking at the data - using a piece of software that's looking at things from a PCM perspective - isn't introducing visual anomalies in the "noisy" high frequencies of the SACD's audio. Or, put another way - looking at film grain from a scanned 35mm negative at 300-400% will look very different, based on the scanner, resolution settings, etc. I think at the end of the day, we're still talking (hearing) apples & oranges.
But, really, this is all moot, as it's very clear that both DVD-A and SACD are phenomenal ways to listen to audio. I'd really like to see an LP comparison along with the CD, DVD-A, and SACD examples!!!
As far as the "compression" analysis, I think this is wholly attributed to the 3 different masterings (CD, DVD-A, SACD), and not so much the formats. In other words, while DVD-A and SACD have the potential for *huge* dynamics, the potential is wasted if it's mastered with aggressive brick wall limiting and other ammunition from the Loudness Wars.
There are further articles that follow that one. Poke around her website. What's your opinion John on just how much 'dynamics' the masters might've had?
I've seen her do a similar comparison with vinyl added to the mix. I don't recall the conclusions, but if I find the link, I'll post it.
And the compression from the "Loudness Wars" is spot on. It's partially responsible for driving me towards more jazz and classical listening (though I was headed that way anyway).
One of the nice things about classical, and that includes vinyl, is that you get an opportunity to hear different conductors with different symphonies, hence different interpretations.
And I think other than not factoring into the analysis the three different mastering processes, this is a very thorough look into the different formats.
No it isn't. There is no baseline whatsoever, and you are looking at three seperate masters, there is no proper calibration, time alignment, and you have three different D/A/ and A/D stages. Interesting, perhaps. Useful, not very. Pretty pictures, yes, but it certainly does not in any way represent the differences in the formats.
Well Jeff, why do you think Sony never made a release with with identical mastering in both scenarios? From the little that I've seen, it always seems that the CD version is more prone to having material on it that's clipped.
