John B. Holbrook
- Dec 21, 2000
Haven't seen this posted elsewhere so I will!
Here are the specifications on the upcoming Sony DVP-NS700P Progressive Scan DVD Player - MSP of about $400.00!!!
Click on the link to see if you'd like to see a picture.
Link Removed
DVP-NS700P PROGRESSIVE SCAN DVD PLAYER
Progressive Video Output with 3-2 Pulldown
CD-R/RW playback
12 Bit / 54 MHz Video DAC (for 480P)
Precision Drive 2
Dynamic Tilt Compensation
TV Virtual Surround
Block Noise Reduction
Dolby Digital/DTS output
Digital Video Enhancer
Digital Video Equalizer
SmoothScan and SmoothSlow modes
10bit Video DACwith 27Mhz processing for 480i output
Component Video Output
Sony Digital Cinema Sound modes
CD and
DVD text
Custom Parental Control
Picture Navigation with
Bookmark, Picture Memory, and Strobe playback
Sound Feedback
Multi-brand remote control
Features
Progressive scan 480P output Delivers beautiful, film-like performance with the latest High-Scan™ and other HD compatible televisions
Full 3-2 reverse conversion The most accurate way to display a film originated DVD, faithfully reproducing the the films frame structure within a video source.
12-bit, 54 Mhz digital to analog converter for 480P output Delivers smoother gradation for more realistic recreation of DVD video
Block Noise Reduction This features helps reduce and remove unwanted "blocks" of information which occur as a result of fast motion and small detail in an image.
Dolby Digital and DTS digital output Connects to a receiver with Dolby Digital and/or DTS built-in
Precision Drive 2 system Providing an improved mechanism for reading DVD discs that are in less than perfect condition, Precision Drive 2 improves over last years Precision Drive to further eliminate errors in playback due to imperfect, scratched or warped DVD discs.
Plays CD-R/RW discs Now you can enjoy the versatility of listening to recorded material from CD-R/RW discs, as well as standard CD's and DVD movies.
Digital Video Enhancer Improves crisp contrast and picture detail, while controlling unwanted artifacts.
Digital Video Equalization Factory preset anad user adjustable settings to optimize picture quality digitally, within the DVD player
SmoothScan and SmoothSlow modes Give you the cleanest playback of DVD in slow motion and scan speeds.
10 bit Video DAC with 27Mhz processing Assures accurate recreation of video with smooth gradations of color and contrast, making a more lifelike picture.
Component Video Output Spearates the vital color components of a video signal, combining them again only when the signal has reached the television. For clear, sharp, and colorful playback of DVD movies.
Digital Cinema Sound DSP system that reproduces the precise acoustics of acclaimed Hollywood mastering stages.
TV Virtual Surround System that generates the effect of surround sound speakers, even when you're limited to the stereo speakers inside your TV.
CD Text and
DVD Text Compatible CD's will display song titles, artist name and disc titles. DVD text equipped discs will display titles, a jacket picture and other information.
Custom Parental Control "Locks" mature-content discs with a four digit code, even if the discs don't carry and MPAA rating.
Picture Navigation With
Bookmark, Picture Memory, and Strobe playback. Makes it easy to access your discs and all of their features
Sound Feedback Feature that gives you a confirmation "beep" when a button is pressed
Multi-brand remote control In addition to Sony televisions, these remote controlsalso operate other brands of television and the volume control for 8 brands of A/V Receiver.
Specifications
Video Horizontal Resolution, DVD 500 TV Lines
Audio Frequency Response (DVD, 96 kHz PCM) 2-44,000Hz, ±0.5 dB
Audio Signal-to-Noise Ratio (DVD, 96 kHz PCM) 110dB
Audio Dynamic Range, DVD 110dB
Harmonic Distortion 0.0025
Weight
11 lbs. 14 oz.
5.4kg
Dimensions
17 x 3 3/4 x 15 3/4"
430 x 94.5 x 411mm
John Holbrook
MY DVD Collection
Link Removed
CD-R/RW playback
Precision Drive 2
TV Virtual Surround
CD and
DVD text
Sound Feedback
Features
CD Text and
Specifications
Weight
11 lbs. 14 oz.
5.4kg
Dimensions
430 x 94.5 x 411mm
John Holbrook
MY DVD Collection
