KevinZ
- Feb 4, 2005
Just moved, tv is now setup on a smaller wall than before and I had a question about setting up the speakers.
When I originally put everything in he room I just put them next to the TV, I haven't even finished setting everything up though. When reading through the manual I noticed one said not to place speakers directly next to a TV unless they are a certain kind of speaker or TV as to not screw with the picture.
The TV is a Pioneer Elite 7200 rear projection
Speakers Paradigm Reference Studio 100
Sub Paradigm PW2200 12"250
With these speakers is it alright to have the speakers next to the TV? Is there a minimum space there should be?
Right now I have it setup along the wall as
Sub - Speaker - TV - Speaker - Component rack
The speakers are fairly close to the TV, the only other option I would have would be
Speaker - Sub - TV - Component rack - Speaker
Which doesn't look nearly as good, and if it doesn't affect or hurt anything I would rather keep it as is.. Figured I should at least ask though
Any advice is greatly appreciated.
